[postgis-users] TopologyException with geomunion
Ethan Alpert ealpert at digitalglobe.com
Wed Nov 2 14:41:52 PST 2005
What version of GEOS? These errors were very frequent in earlier
versions but still occur. One thing I found was GEOS doesn't like
identical polygons in the same geomunion.
-e
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
David Orme
Sent: Wednesday, November 02, 2005 8:33 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] TopologyException with geomunion
Hi all,
I've run into an exception when trying to union two multipolygons.
The features are both simple and valid:
range_maps=# select isvalid(geom), issimple(geom) from viverrid_psar
where node_number in (-3,-21);
isvalid | issimple
t       | t
t       | t
(2 rows)
but when I try and union these I get the following:
range_maps=# insert into viverrid_psar (taxon_name, node_number,
subclades, branch_length,  n_tips, n_subclades, node_height,
richness, geom)values ('',-2,'{-3,-21}',9.9,31,2,18.1,31,(select
geomunion(geom) from viverrid_PSAR where node_number in (-3,-21)));
NOTICE:  TopologyException: Directed Edge visited twice during ring-
building at  (1.13203e+07,402571)
ERROR:  GEOS union() threw an error!
I don't think I'm doing something dumb, but I thought I'd check
before I start posting bug reports..
Cheers,
David
postgis-users mailing list postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
