[postgis-users] postgis.sql
Maik Trömel maik.troemel at maitro.net
Wed Nov 9 03:30:45 PST 2005
Ok, now it works.
Thanks a lot!
Greeting from Germany
Maik
strk at refractions.net wrote:
>postgis.sql has been renamed to lwpostgis.sql
>since version 1.0.
>Please file a bug report for dox updates.
>Thanks.
>--strk;
>On Wed, Nov 09, 2005 at 10:46:37AM +0100, Maik Trömel wrote:
>>Hello Postgis-Users,
>>I try to run Postgis under Debian.
>>I have installed libpostgis1-pg74_1.0.0-1_i386.deb.
>>Then I followed the instructions of a web tutorial:
>>- I created a db. That works.
>>- Then I proceeded with "createlang plpgsql [dbname]".  -> works
>>- Then I tried to load postgis.sql with "psql -d [dbname] -f
>>postgis.sql" -> "postgis.sql: No such file or directory"
>>- Where can I get this file from or what must I do?
>>Thanks for your help!
>>Greetings
>>Maik
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
