[postgis-users] Error in SPATIAL_REF_SYS table
Jan Hartmann j.l.h.hartmann at uva.nl
Wed Nov 9 09:59:32 PST 2005
Hi Barend,
The problem lies in PROJ4's  projection definition of EPSG:28992, the
Dutch National Grid. This is "stere" (Stereographic), but can be better
approximated by "sterea" (Oblique Stereographic Alternative). I don't
think it has to do with the original EPSG database; it has to do with
the way PROJ4 handles coordinate systems that use epsg code 9809. There
has been a long discussion on the October PROJ4 mailing list on this
projection. It starts at
http://lists.maptools.org/pipermail/proj/2005-October/001817.html
and see also all postings under the subject "Roussilhe"
A bugreport has been entered in PROJ4's Bugzilla:
http://bugzilla.remotesensing.org/show_bug.cgi?id=980
In the meantime, I have found (with the help of Kees Krikke,
krikke at nlr.nl), that a more accurate definition for the Dutch system is:
+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
+k=0.999908 +x_0=155000 +y_0=463000 +ellps=bessel  +units=m
+towgs84=565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.8703473836068,4.0812
+no_defs +to +proj=latlong +datum=WGS84
The "towgs84" parameter is also missing in the PROJ4 epsg table
(although it is in the original EPSG database). You need it for
overlaying on WGS84-based maps, like Google Earth. This formula gives
precision from 1 mm to about 25 cm, compared to the "official"
transformation available at http://www.rdnap.nl. The remaining 25 cm are
due to corrections needed for the slightly irregular Dutch grid, and are
almost impossible to incorporate into PROJ (see
http://lists.maptools.org/pipermail/proj/2005-October/001809.html).
You can put this definition into your local epsg file and
spatial_ref_sys table until the official PROJ update.
HTH
Jan Hartmann
Department of Geography
University of Amsterdam
Barend Köbben wrote:
> Hi there,
> I just started using PostGIS instead of the Spatial Extensions of MySQL, mainly because of the lack of SRID support in the latter. Everything went nicely until yesterday, when I found that there's an error in the SPATIAL_REF_SYS table for the Dutch National Grid. This, officialy called "RijksDriehoeksstelsel" is defined with Projection = Oblique Stereographic. But it should be Double Stereographic...
> All the other coordinates seem right, but the result is still an offset of about 2 meters when combined with properly projected data....
> Any ideas on how this could be remedied, or should I file a bug report?
> ____________________________
> Barend Köbben
> International Institute for Geo-information
> Sciences and Earth Observation (ITC)
> PO Box 6, 7500AA Enschede (The Netherlands)
> ph: +31 (0)53 4874253; fax: +31 (0)53 4874335
> postgis-users mailing list
