[postgis-users] Script
Robert Burgholzer rburghol at chesapeakebay.net
Wed Nov 9 10:17:21 PST 2005
If you are using the psql command line connection to Postgresql, then the following syntax will execute an SQL file named "scriptname.sql" that resides in the current working directory (where you invoked the psql command)"
\i scriptname.sql
HTH
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Maik Trömel
Sent: Wednesday, November 09, 2005 10:32 AM
To: Postgis Users
Subject: [postgis-users] Script
Hi PostGIS-Users,
how can I run a script under postgresql?
Thanks for your help!
Greetings
Maik
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
