[postgis-users] Script
Maik Trömel maik.troemel at maitro.net
Thu Nov 10 00:33:59 PST 2005
Thanks!
That is what i searched!
Greetings
Maik
alex bodnaru wrote:
>you could also use psql in batch mode:
>psql -d your_database -f scriptname.sql,
>or
>psql -d your_database < scriptname.sql
>alex
>Robert Burgholzer wrote:
>>If you are using the psql command line connection to Postgresql, then the following syntax will execute an SQL file named "scriptname.sql" that resides in the current working directory (where you invoked the psql command)"
>>\i scriptname.sql
>>HTH
>>-----Original Message-----
>>From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Maik Trömel
>>Sent: Wednesday, November 09, 2005 10:32 AM
>>To: Postgis Users
>>Subject: [postgis-users] Script
>>Hi PostGIS-Users,
>>how can I run a script under postgresql?
>>Thanks for your help!
>>Greetings
>>Maik
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
