[postgis-users] pg_dump -Fc vs pg_dumpall for daily backups
Blair Zajac blair at orcaware.com
Mon Nov 14 22:55:33 PST 2005
Thank you, to both you and to Michael, for clarifying the situation.
Regards,
Blair
strk at refractions.net wrote:
> Briefly: you SHOULD NOT need postgis_restore.pl if not upgrading postgis.
> Note that if you upgrade postgresql, you *might* need it, as some postgis
> scripts are sensitive to database version (consider schema support for
> example).
> --strk;
