[postgis-users] trouble with moving data
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Wed Nov 16 01:04:53 PST 2005
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Sears, Jeremy
> Sent: 15 November 2005 20:13
> To: 'postgis-users at postgis.refractions.net'
> Subject: [postgis-users] trouble with moving data
> Good day all,
> Im attempting to load GIS data into PostgreSQL 8.1.
> I have a fresh install on a winXP machiene. My data are in a
> dump file that was produced by an earlier version of the
> database using pg_dump exe. I have tried to load these data
> into my new database using the pg_restore command. I get no
> errors however no data are loaded. After a number of attempts
> the best I seem to get is that pg_restore will create my
> schema and tables, but wont populate the tables wih data.
> Has anyone had a simmilar experience? What am I missing?
> Any suggestions or comments are welcome.
> Many Thanks
> Jeremy
Hi Jeremy,
You probably want to take a look at this thread here:
http://postgis.refractions.net/pipermail/postgis-users/2005-October/009730.h
tml. Perhaps this needs to be featured more prominently in an FAQ or on the
Wiki somewhere?
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
