[postgis-users] installing postgis in Ubuntu 5.10(Breezy)
alex bodnaru alexbodn at 012.net.il
Thu Nov 17 08:27:38 PST 2005
the *c2 dependency is been automatically added on relevant platforms only.
if you make postgis from sources in an 4.01 environment, the dependency
will be libgeos2, instead of libgeos2c2.
i'm sending the sources, so that you will try and be convinced.
alex
John Taber wrote:
> alex bodnaru wrote:
>> if you have postgresql-common installed, i might send you the packages
>> later.
> I appreciate your help, but I think you are working in unstable with
> libstdc++ 4.02 and I'm in Breezy with libstdc++4.01.  If Blair can fix
> his pkg then that gives Breezy users both postgresql 8.1 & postgis.
> postgis-users mailing list
Type: application/x-tar
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051117/6b188b95/attachment.tar>
