[postgis-users] Re: a line's direction
Amit Kulkarni amitkulz at yahoo.com
Thu Nov 17 13:59:09 PST 2005
referring to Hartmut Tschauner's post here
http://postgis.refractions.net/pipermail/postgis-users/2005-September/009260.html
I used that function to correctly set the digitized direction of all
road segments for a given road (Thanks Hartmut!). I am hoping somebody
will integrate something like this in the next 1.0.5 (or 1.0.6) release
for general use. This is probably what most people who are checking
roads would run up against.
If its already being done or planned, ignore this message.
(It would be called like this)
to initially check for bad direction and rerun this query afterwards to
doublecheck if everything was done...
SELECT r."ID1", azimuth(startpoint(the_geom), endpoint(the_geom)) as
azimuth, r."ROAD_LABEL" FROM "Roads" as r where r."ROAD_LABEL"=
'FLORIDA BLVD';
to actually run the stored proc, a dummy select
select * from align_direction('FLORIDA BLVD','0');
Thanks in advance
__________________________________
Yahoo! FareChase: Search multiple travel sites in one click.
http://farechase.yahoo.com
Type: text/sql
Desc: 506041946-postgis_align_direction.sql
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051117/314970e2/attachment.bin>
