[postgis-users] Linux versions?
Gregory S. Williamson gsw at globexplorer.com
Mon Nov 21 02:08:20 PST 2005
Are you sure you got a full install on windows ? I used the Windoze installer and got this:
D:\psql\bin>dir
 Volume in drive D is Local Disk
 Volume Serial Number is 20C7-BDDD
 Directory of D:\psql\bin
07/13/2005  02:13a      <DIR>          .
07/13/2005  02:13a      <DIR>          ..
11/29/2003  10:39p              17,764 adddepend.pl
09/10/2004  04:31a               3,227 clean_pending.pl
07/06/2005  01:41a             158,117 pgsql2shp.exe
05/11/2005  10:17a              55,674 pg_autovacuum.exe
05/11/2005  10:16a              36,612 pg_config.exe
05/11/2005  10:16a              42,410 pg_controldata.exe
05/11/2005  10:15a              67,062 pg_ctl.exe
05/11/2005  10:15a             292,848 pg_dump.exe
05/11/2005  10:15a              74,142 pg_dumpall.exe
05/11/2005  10:17a              39,075 pg_dumplo.exe
05/11/2005  10:16a              63,279 pg_resetxlog.exe
05/11/2005  10:15a             189,347 pg_restore.exe
05/18/2005  09:01a              14,001 postgis_restore.pl
05/11/2005  10:14a           3,089,716 postgres.exe
05/11/2005  10:14a           3,089,716 postmaster.exe
05/11/2005  10:15a             237,854 psql.exe
And it does work:
D:\psql\bin>psql -d template1 -U ssf
Password:
Greg Williamson
DBA
GlobeXplorer LLC
-----Original Message-----
From:	postgis-users-bounces at postgis.refractions.net on behalf of Markus Schaber
Sent:	Mon 11/21/2005 2:03 AM
To:	PostGIS Users Discussion
Cc:
Subject:	Re: [postgis-users] Linux versions?
Hi, Daryll,
Darryl Watson wrote:
> Currently, I have PostGIS and PostgreSQL installed on a Windows server,
> which is annoying, because there are no command line utilities
> available.
It sounds surprising to hear that psql and the other utilities are
missing on PostgreSQL/Windows.
> So, since I don't have extra hardware for a Linux box, I
> want to install Linux in a VMWare virtual machine and run PostGIS from
> there.
Hmm, maybe CoLinux http://www.colinux.org/ or CygWin
http://www.cygwin.com/ can help you, too.
> My primary question is what Linux distributions do I want to avoid, and
> which work easily with PostGIS?
> My preferred distributions are Suse Linux 9.2, 9.3, Redhat Fedore Core
> 4, or Red Hat Enterprise 4.  I don't care for Debian or Ubuntu.
So you ask us a question and at the same time you tell us that you're
not interested in the correct answer? :-)
Markus
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
!DSPAM:438194fe175901891821090!
