[postgis-users] shp2pgsql DBF-Column type boolen wrong
Düster Horst Horst.Duester at bd.so.ch
Tue Nov 22 05:25:19 PST 2005
I try to convert a shapefile with one column of type boolean via shp2pgsql.
In the resulting pgsql table this column appears as type varchar instead of
type boolean. I found out the following facts:
- Coversion shp->pgsql:
	shp2pgsql -d¦-c ...	boolean is changed to varchar
	shp2pgsql -a		boolean is correct when in table definition
the field is defined as boolean
- Conversion pgsql->shp		works correct, table boolean appears as shp
boolean
My system:
Windows
  shp2pgsql 1.88.2.7
  pgsql2shp 1.74.2.4
Linux
 Postgresql 8.1
 Postgis 1.0.4
I would be grateful for any hint.
Regards
Dr. Horst Düster
GIS-Koordinator, Stv. Amtsvorsteher
Kanton Solothurn
Amt für Geoinformation
Abteilung SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
Tel.: ++41 (0)32 627 25 32
Fax: ++41 (0)32 627 22 14
horst.duester at bd.so.ch
www.sogis.so.ch
