[postgis-users] Query crashed
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Tue Nov 22 07:19:19 PST 2005
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Mikael Carneholm
> Sent: 22 November 2005 13:24
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] Query crashed
> Thanks, that worked:
> create or replace function createbb2(latitude numeric, longitude numeric,
> size_m integer) returns box3d as $$
> declare
> 	latlong_multiplier numeric := 0.0000111319;
> begin
> 	return expand( makepoint(latitude,longitude),
> (size_m*latlong_multiplier) )::box3d;
> end;
> language plpgsql immutable;
> explain analyze
> select
>       p.point__id,
>       p.latitude,
>       p.longitude,
>       p.altitude_meters
> from point p
> where p.geo && SetSRID(createbb2(53.948821,10.858131,1000), 3007)
>      and distance (
>         p.geo,
>         creategeom(53.948821,10.858131,3007)
>     ) <= 1000;
> QUERY PLAN
>  Index Scan using idx_point_geo on point p  (cost=0.00..6.02 rows=1
> width=45) (actual time=1.921..33.662 rows=414 loops=1)
>    Index Cond: (geo &&
> '0103000020BF0B000001000000050000000000002006F84A40000000C0A9B125400000002
> 006F84A400000002010BD2540000000C0DFFA4A400000002010BD2540000000C0DFFA4A400
> 00000C0A9B125400000002006F84A40000000C0A9B12540'::geometry)
>    Filter: (distance(geo, creategeom(53.948821, 10.858131, 3007)) <=
> 1000::double precision)
>  Total runtime: 34.407 ms
> Still, I would be happier if the box3d parser was fixed. Anyone working on
> that?
> /Mikael
Hi Mikael,
Glad you got your query to work :) As for the BOX3D parser, that's probably
something for strk to look at....
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
