[postgis-users] shp2pgsql DBF-Column type boolen wrong
strk at refractions.net strk at refractions.net
Tue Nov 22 14:29:00 PST 2005
The revision of shp2pgsql should already handle
boolean values correctly, as long as they are tagged
as FTLogical in the dbf.
On the other hand, it seems that pgsql2shp does *never*
set dbf fields as FTLogical, so the "bug" would be
in the dumper, not the loader.
Would you file a bug report in the bug tracker so I'll
try to do this for 1.0.5 (scheduled this Friday) ?
--strk;
On Tue, Nov 22, 2005 at 02:25:19PM +0100, Düster Horst wrote:
> I try to convert a shapefile with one column of type boolean via shp2pgsql.
> In the resulting pgsql table this column appears as type varchar instead of
> type boolean. I found out the following facts:
> - Coversion shp->pgsql:
> 	shp2pgsql -d¦-c ...	boolean is changed to varchar
> 	shp2pgsql -a		boolean is correct when in table definition
> the field is defined as boolean
> - Conversion pgsql->shp		works correct, table boolean appears as shp
> boolean
> My system:
> Windows
>   shp2pgsql 1.88.2.7
>   pgsql2shp 1.74.2.4
> Linux
>  Postgresql 8.1
>  Postgis 1.0.4
> I would be grateful for any hint.
> Regards
> Dr. Horst Düster
> GIS-Koordinator, Stv. Amtsvorsteher
> Kanton Solothurn
> Amt für Geoinformation
> Abteilung SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Tel.: ++41 (0)32 627 25 32
> Fax: ++41 (0)32 627 22 14
> horst.duester at bd.so.ch
> www.sogis.so.ch
> postgis-users mailing list
 /"\    ASCII Ribbon Campaign
 \ /    Respect for open standards
  X     No HTML/RTF in email
 / \    No M$ Word docs in email
