[postgis-users] SQL query to identify tables and views with geometry field
jcradock at me3.com jcradock at me3.com
Fri Nov 25 11:43:25 PST 2005
Armin,
Ah.
Look in pg_catalog. I believe qGIS is querying these tables. Probably
pg_attribute joined to pg_type joined to pg_table.
http://www.postgresql.org/docs/8.1/interactive/catalogs.html
Jim
> But this query does not find the views based on tables, even if the
> tables themselves are registered in geometry_columns. Programs like QGIS
> and uDig seem to be able to find all tables and views with geometry
> columns, so I guess there seems to be a SQL query based on PG system
> tables for this.
> Armin
> Sean Gillies wrote:
>> On Nov 25, 2005, at 12:28 PM, Armin Burger wrote:
>>> Hi everyone,
>>> is there a way to find all tables and views in a PostGIS-enabled
>>> database that contain a geometry field, using just a SQL query?
>>> Armin
>> If your database is in proper shape
>>   select f_table_name from geometry_columns;
>> cheers,
>> Sean
>> Sean Gillies
>> sgillies at frii dot com
>> http://zcologia.com/news
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
James Cradock, jcradock at me3.com
