[postgis-users] Making shp2pgsql using iconv in /usr/local?
Mike Leahy mgleahy at alumni.uwaterloo.ca
Wed Nov 30 17:12:16 PST 2005
Hey there,
I think this problem might be related to a bug found with MapServer a
while back: http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=909
I tried commenting out the following lines in /usr/local/include/iconv.h
(version 1.10), and PostGIS compiled without errors:
45: //#undef iconv_t
46: //#define iconv_t libiconv_t
70: //#define iconv_open libiconv_open
80: //#define iconv libiconv
86: //#define iconv_close libiconv_close
96: //#define iconvctl libiconvctl
119: //#define iconvlist libiconvlist
I have no idea if this breaks anything...I just figured it was related
to conflicting libraries as suggested in the MapServer bug referenced above.
I'm running FC4, with the most recent upgrades.
I hope this helps.
Mike
Larry Shaffer wrote:
> strk,
> Sorry for the lack of info on my part. I'd like to get this working, but
> it's no big thing until I get ready to install the upcoming PostGIS 1.0.6
> version, as this is a brand new setup (PostgreSQL and all) with no real
> data installed into yet.
> Make for PostGIS works fine with USE_ICONV ?= 0
> My src path is /usr/local/src/postgresql-8.1.0/contrib/postgis
> These are the values in the PGISSRC/Makefile.config:
> USE_PROJ ?= 1
> PROJ_DIR ?= /usr/local
> USE_GEOS ?= 1
> GEOS_DIR ?= /usr/local
> USE_JTS ?= 0
> JTS_INCLUDES = /usr/local/include
> JTS_LIBDIR = /usr/local/lib
> USE_STATS=1
> AUTOCACHE_BBOX ?= 1
> PGSQL_SRC=/usr/local/src/postgresql-8.1.0
> USE_ICONV ?= 1
> (set to 0 for PostGIS make, then to 1 for shp2pgsql make)
> LPATH=/usr/local/src/postgresql-8.1.0/contrib/postgis
> What's in /usr/local/lib
> libiconv_plug.so
> libiconv.la
> libiconv.so
> libiconv.so.2
> libiconv.so.2.2.0
> What's in /usr/local/include
> iconv.h
> and whereis?
> sh-2.05a# whereis libiconv
> libiconv: /usr/local/lib/libiconv.so /usr/local/lib/libiconv.la
> sh-2.05a# whereis iconv
> iconv: /usr/bin/iconv /usr/local/bin/iconv /usr/include/iconv.h /usr/
> share/man/man1/iconv.1.gz /usr/share/man/man3/iconv.3.gz
> (Where is /usr/local/include/iconv.h? It *does* exist in /usr/local/
> include. This could be the problem...)
> Running  iconv -l  for /usr and /usr/local provides positive results of
> listing encodings (i.e. both are working).
> sh-2.05a# /usr/bin/iconv --version
> iconv (GNU libc) 2.2.5
> Copyright (C) 2002 Free Software Foundation, Inc.
> Written by Ulrich Drepper.
> sh-2.05a# /usr/local/bin/iconv --version
> iconv (GNU libiconv 1.9)
> Copyright (C) 2000-2002 Free Software Foundation, Inc.
> Written by Bruno Haible.
> I installed the libiconv-1.9.1 from GNU since it was a standalone.
> Should I install the Standard C library (glibc-2.3.2) in /usr/local ? I
> don't think the /usr/local extras before make command of shp2pgsql are
> making a difference, so I don't think it's worth the effort right now.
> See the following...
> Here's the output from the /usr/local extras
> (run from within contrib/postgis/loader)
> sh-2.05a# LDFLAGS="-L/usr/local/lib -liconv" CFLAGS="-I/usr/local/
> include" make shp2pgsql
> make: `shp2pgsql' is up to date.
> sh-2.05a# make clean
> rm -f shpopen.o dbfopen.o getopt.o PQunescapeBytea.o shp2pgsql.o
> pgsql2shp.o shp2pgsql pgsql2shp
> gcc -g -Wall -I.. -I. -I/usr/local/src/postgresql-8.1.0/src/interfaces/
> libpq -O2 -Wall -Wmissing-prototypes -Wpointer-arith -Winline -fno-
> strict-aliasing -DUSE_ICONV -DFRONTEND -DSYSCONFDIR='"/usr/local/pgsql/
> etc"' -DUSE_VERSION=81 -I/usr/local/src/postgresql-8.1.0/src/include -
> D_GNU_SOURCE  -I/usr/local  -c -o shpopen.o shpopen.c
> shpopen.c:176: warning: `rcsid' defined but not used
> D_GNU_SOURCE  -I/usr/local  -c -o dbfopen.o dbfopen.c
> dbfopen.c:200: warning: `rcsid' defined but not used
> D_GNU_SOURCE  -I/usr/local  -c -o getopt.o getopt.c
> D_GNU_SOURCE  -I/usr/local  -c -o PQunescapeBytea.o PQunescapeBytea.c
> D_GNU_SOURCE  -I/usr/local  -c -o shp2pgsql.o shp2pgsql.c
> etc"' -DUSE_VERSION=81 shpopen.o dbfopen.o getopt.o PQunescapeBytea.o
> shp2pgsql.o -L/usr/local/src/postgresql-8.1.0/src/port -lstdc++  -L/usr/
> local -Wl,-rpath,/usr/local/pgsql/lib -o shp2pgsql
> shp2pgsql.o: In function `utf8':
> /usr/local/src/postgresql-8.1.0/contrib/postgis/loader/shp2pgsql.c:1630:
> undefined reference to `libiconv_open'
> /usr/local/src/postgresql-8.1.0/contrib/postgis/loader/shp2pgsql.c:1648:
> undefined reference to `libiconv'
> /usr/local/src/postgresql-8.1.0/contrib/postgis/loader/shp2pgsql.c:1654:
> undefined reference to `libiconv_close'
> collect2: ld returned 1 exit status
> make: *** [shp2pgsql] Error 1
> and without the /usr/local extras... just 'make shp2pgsql'...
> exactly the same results.
> I don't think /usr/local/include/incov.h is being located. Either way,
> it's failing to make when using the base install of Debian
> [linus]$ uname -a
> Linux linus 2.4.28-grsec+w+fhs6b+gr0501+nfs+++p4+c4+gr6b-v6.188 #1 SMP
> Fri Jan 14 11:41:59 PST 2005 i686 unknown
> Any help would be appreciated. Thanx.
