[postgis-users] Restore woes Postgres 8.0.3 / Postgis 0.9.1 toPostgres 8.1 b3 / Postgis 1.0.4 on Windows
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Mon Oct 24 06:33:51 PDT 2005
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users
bounces at postgis.refractions.net] On Behalf Of Johan Wehtje
> Sent: 22 October 2005 02:07
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Restore woes Postgres 8.0.3 / Postgis 0.9.1
> I have a Database that was created postgres 8.0.3 with Postgis 0.9.1
(installed using
> PgInstaller).
> I wanted to dump and restore the DB to Postgres 8.1 b3 which ships with
Postgis 1.0.4
> but every option that I try fails when it comes to the spatial tables.
Hi Johan,
Just for the record, I was unable to provide Dave with a working 1.0.4 Win32
build of PostGIS in time for 8.1 beta 3, however it should be included in
8.1 beta 4. This will only affect you if you are building GiST indices on
large tables.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
