[postgis-users] How does makeline work?
Guido Lemoine guido.lemoine at jrc.it
Fri Sep 9 00:16:42 PDT 2005
Hi all,
I am having some trouble getting makeline to work correctly. According
to the manual, it will accept a set of point geometries. For my application,
it is important to keep the order of the points  (ultimately, I use it
to create a closed polygon that describes the outer bounds of a
satellite image
ground control points. I get the GCPs from gdalinfo).
My GCP table is of type (gcp_id integer not null, gcp_geom geometry). gcp_id
is a unique sequential number, gcp_geom is a point (lon, lat).
 select astext(makeline(gcp_geom)) from testset;
works fine, but I want to revert the order of the point sequence.
select astext(makeline(gcp_geom)) from testset order by gcp_id desc;
ERROR:  column "testset.gcp_id" must appear in the GROUP BY clause or be
used in an aggregate function
this doesn't work, but that is to be expected for an aggregate function.
select astext(makeline(gcp_geom)) from testset where gcp_geom IN (select
gcp_geom from testset order by gcp_id);
this works, and produces the same line as when not using the where.
gcp_geom from testset order by gcp_id desc);
Now, I would expect the same line, but in reverse order. But this is not
the case (it's the same as before).
The manual says "You might want to use a subselect to order points
before feeding them to this aggregate",
and this gave me hope. My current workaround is a plpgsql function that
solves the problem, but it's a bit
awkward.
Any help appreciated
Guido Lemoine.
