Hi all,
I am having some trouble getting distance to work correctly with 3d
geometries.
I have tried with a "select" simple to see as it worked.
The results are not those that hoped.
I do not understand it.
$ uname -a
FreeBSD Silvanesti 5.4-RELEASE FreeBSD 5.4-RELEASE #0: Mon May 23 12:17:48
CEST 2005 root at Silvanesti:/usr/obj/usr/src/sys/MYKERNEL i386
$ psql -d dister05
Welcome to psql 7.4.7, the PostgreSQL interactive terminal.
Type: \copyright for distribution terms
\h for help with SQL commands
\? for help on internal slash commands
\g or terminate with semicolon to execute query
\q to quit
dister05=# select postgis_full_version();
POSTGIS="1.0.0RC3" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS DBPROC="0.2.0"
RELPROC="0.2.0"
(1 row)
ister05=# select
dister05-# distance(
dister05(# MakeLine(MakePoint(200,200), MakePoint(400,200)),
dister05(# MakeLine(MakePoint(300,100), MakePoint(300,300))
dister05(# )::int as A_Expected0, -- expected 0, ok
dister05(# MakeLine(MakePoint(200,200,10), MakePoint(400,200,10)),
dister05(# MakeLine(MakePoint(300,100,10), MakePoint(300,300,10))
dister05(# )::int as B_Expected0, -- expected 0, ????
dister05(# MakeLine(MakePoint(200,200, 0), MakePoint(400,200, 0)),
dister05(# MakeLine(MakePoint(300,100,100), MakePoint(300,300,100))
dister05(# )::int as C_Expected100, -- expected 100, ????
dister05(# MakeLine(MakePoint(200,200,0), MakePoint(400,200,100)),
dister05(# MakeLine(MakePoint(300,100,0), MakePoint(300,300,100))
dister05(# )::int as D_Expected50 -- expected 50 aprox., ????
dister05-# ;
a_expected0 | b_expected0 | c_expected100 | d_expected50
0 | 26 | 0 | 28
(1 row)
dister05=#
The second column is the same that first but with an elevation of 10 (z=10).
Because it is not zero?
In the third column the lines are not crossed in the space.
The lines are in different planes (z=0, z=100).
That I can be making bad?
Best regards,
Joaquin
P.S. Sorry for my terrible English.
______________________________________________
Renovamos el Correo Yahoo!
Nuevos servicios, más seguridad
http://correo.yahoo.es
