[postgis-users] PostGIS and Mapserver
Randy James rjames57 at yahoo.com
Fri Sep 16 11:05:05 PDT 2005
in your pg_hba.conf you need to give permission to use the connection and example
in the file is like this
# host    all         all         127.0.0.1         255.255.255.255   trust
in the postgresql.conf file enable the tcpic connection like this:
tcpip_socket = true
Your problems are postres problems not postgis or mapserver, look in your
posgresql documents.
--- Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br> wrote:
> but I can enter on the db via ssh connection.
> This have any difference from entering via apache ?
> Ezequias
> Randy James wrote:
> >looks like the error for the fix listed as number 4
> >>Hi list,
> >>I am trying to access postgis via mapserver (a cgi server) but the
> >>resoult is allways a problem. Could anobody take a look on my problem ?
> >>the stack trace is shown below:
> >>msDrawMap(): Image handling error. Failed to draw layer named 'bairros'.
> >>msPOSTGISLayerOpen(): Query error. couldnt make connection to DB with
> >>connect string 'user=postgres password=pt dbname=db1
> >>host=myserver.mydomain port=5432'.
> >>Error reported was 'could not create socket: Permission denied '.
> >>This error occured when trying to make a connection to the specified
> >>postgresql server.
> >>Most commonly this is caused by
> >>(1) incorrect connection string
> >>(2) you didnt specify a 'user=...' in your connection string
> >>(3) the postmaster (postgresql server) isnt running
> >>(4) you are not allowing TCP/IP connection to the postmaster
> >>(5) your postmaster is not running on the correct port - if its not on
> >>5432 you must specify a 'port=...'
> >>(6) the security on your system does not allow the webserver (usually
> >>user 'nobody') to make socket connections to the postmaster
> >>(7) you forgot to specify a 'host=...' if the postmaster is on a
> >>different machine
> >>(8) you made a typo
> >>My best regards
> >>Ezequias
> >>_______________________________________________
> >>postgis-users mailing list
> >>postgis-users at postgis.refractions.net
> >>http://postgis.refractions.net/mailman/listinfo/postgis-users
> >Yahoo! Mail - PC Magazine Editors' Choice 2005
> >http://mail.yahoo.com
__________________________________________________
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam protection around
