[postgis-users] Crosses Performance
David Bitner osgis.lists at gmail.com
Tue Sep 20 10:35:40 PDT 2005
I'm looking at optimizing a query of mine that takes a uniform set of grid
cells and determines how many aircraft flight tracks cross each grid cell.
As the lines are long and the area of interest is relatively small, the &&
and geometry index don't do much, most of the index speed comes from
filtering the flight tracks based on time (as of now there are over half a
million flight track records and this is likely to increase to over 2
million).
I have two approaches that I have thought of that might speed up these
queries that I wanted to see if anyone could comment on whether they (or any
other ideas) are likely to result in any significant performance gain.
The first approach:
The flight track data points that make up the line are taken by radar at an
interval of 4 seconds, as most tracks are fairly straight, a simplify
operation would decrease the size drastically, but I really need to maintain
the high accuracy of the crossing. My idea is to maintain two geometry
columns, the original and a majorly simplified geometry. I would then do a
first pass using the distance(simple_geom,grid)<tolerance where tolerance is
the value that I used for simplification. Then from those results do a
distance(first_result_geom,grid)=0. This adds a whole other step, but I
believe the distance query agains a much simpler (I think between one tenth
and one third the number of points) might be fast enough to jusitify the
additional step.
The second approach:
Maintain all of the points from the lines as a point dataset as well and
just do a count on the unique id's of points that fall within the time
period and the grid geometry.
The point of this query is to provide a density map of flight tracks over an
area during a period of time for display in Mapserver so performance is
critical, right now I limit the time period to a single day and I make my
grid cells rather large to keep my draw time reasonably fast, but I am
really tring to get a nice surface to display for time periods orders of
magnitude longer.
Thanks for any pointers or advice,
David
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050920/4df2b2c6/attachment.html>
