[postgis-users] Question to canonical form and SRID
Gregory S. Williamson gsw at globexplorer.com
Sat Apr 8 18:12:49 PDT 2006
Kai --
I don't think you can get postGIS to show the data in a text format without using a function ... AsEWKT(the_geom) will show the data with the SRID; AsWKT shows it without the SRID data.
The find_srid(db/schema, table, column) will return the SRID for a given table and column if the geometry_columns table has appropriate entries.
select SRID(the_geom) will return the SRIDs in a given table but actually goes through the whole table checking, so is slower than the one above, I think.
HTH,
Greg WIlliamson
DBA
GlobeXplorer LLC
-----Original Message-----
From:	postgis-users-bounces at postgis.refractions.net on behalf of Kai Behncke
Sent:	Sat 4/8/2006 8:27 AM
To:	postgis-users at postgis.refractions.net
Cc:
Subject:	[postgis-users] Question to canonical form and SRID
Hello everybody, I`m Postgis-beginner
and I would like to know, if it`s possible
to get my geometry-entries automatically in the WKT-Form (and not in the
canonical-form) if I wan`t to look at them in pgadmin3?
I know, that I can use "SELECT AsText(the_geom) from xyz",
but I would like to see the text-from directly.
And a second question please:
How do I need to insert the geometry to get back an entry like:
"SRID=32632;POINT(3455632 6787989)".
So far, I have made it that I cann see in "the_geom"-> POINT(3455632
6787989)
and in the table geometry_columns is the SRID-Code written, but how can I
see the SRID directly in the geometry?
Thank you very much, Kai Behncke
"Feel free" - 10 GB Mailbox, 100 FreeSMS/Monat ...
Jetzt GMX TopMail testen: http://www.gmx.net/de/go/topmail
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
!DSPAM:4437d652213361804284693!
