[postgis-users] doesn't see postgresql
Gregory S. Williamson gsw at globexplorer.com
Sat Apr 8 23:36:41 PDT 2006
After you have a database created:
CREATE DATABASE foo;  -- options, etc. not shown
>From a command line run:
createlang plpgsql foo
If createlang is not in your path you will need to refer to it expicitly with path included; it is in the same directory as psql and the other postgres executables.
Then try to create postGIS, which needs to use the plpsql language in its functions.
HTH,
Greg WIlliamson
DBA
GlobeXplorer LLC
-----Original Message-----
From:	postgis-users-bounces at postgis.refractions.net on behalf of Randy Burkhardt
Sent:	Sat 4/8/2006 10:02 PM
To:	PostGIS Users Discussion
Cc:
Subject:	Re: [postgis-users] doesn't see postgresql
Hi Steffen,
 to install postgis-1.1.1, from a postgis-1.1.1 directory
#  .configure
I get about the first 30 checks for things needed for postgis successfully
"..yes"
then
checking for pg_config... no
configure: error: PostgreSQL is required by PostGIS
On 4/8/06, Steffen Macke <sdteffen at gmail.com> wrote:
> Hello Randy,
> > How can I get postgis to see I have postgresql-8.1.3 running?
> What is the step where something is going wrong?
> Do you get an error message?
> I don't know much about Red Hat, but maybe you can simply install the
> Fedora RPM(s):
> http://postgis.refractions.net/rpms/fedora/fedora-core-4/
> Regards,
> Steffen
> postgis-users mailing list
!DSPAM:4438957f313321402113762!
