[postgis-users] PostGIS' gentoo ebuild and PostGIS manual transalation
Gérald Fenoy djayweb at djayux.net
Mon Apr 10 10:09:39 PDT 2006
Hi ronald,
you have it, just try an ls /usr/portage/dev-db/postgis/postgis-1.1.2
then you'll find it. But as you could understand, this version, as it's
the rule in gentoo, is not concidered as a stable release. So the
lastest ebuild is (as we said) "masked". But you could unmask this
ebuild as you do for others packages.
You have various methods for unmasking ebuilds, but for my part I prefer
this one : edit the file /etc/portage/package.keywords to add this
line : "dev-db/postgis ~x86". Then retry an "emerge -s postgis" and
you'll must find the lastest version available.
Hope that answer your query.
regards,
ps: you could maybe help me, indeed by now I don't have an amd64 arch
machine to make my tests on it :/ so if you have any troubles with this
version thanks to report a bug on the gentoo's bugzilla (and you could
also send me feedbacks at the same time).
Le lundi 10 avril 2006 à 12:22 +0200, "R. Müller" a écrit :
> nice to hear,
> but i actually can't find it... :-(
> my gentoo says only (after sync) :
> $uname -a
> linux 2.6.14.2 #4 Thu Jan 26 10:08:45 CET 2006 x86_64 AMD Athlon(tm) 64
> Processor 3000+ AuthenticAMD GNU/Linux
> $emerge -s postgis
> *  dev-db/postgis
>        Latest version available: 1.0.1_p20050805
>        Latest version installed: [ Not Installed ]
>        Size of downloaded files: 1,414 kB
>        Homepage:    http://postgis.refractions.net
>        Description: Geographic Objects for PostgreSQL
>        License:     GPL-2
> regards
> ronald
> Gérald Fenoy wrote:
> > Hi folks,
> > I'm proud to anounce you that the new 1.1.2 version is available on the
> > official gentoo portage tree. I hope that you'll be numerous to test it
> > and, if applicable, report a bug on the gentoo's bugzilla
> > (http://bugs.gentoo.org).
> > Yesterday we've made some changes on postgis.fr to be able to translate
> > the official PostGIS Manual in french. So I call all french people to
> > come on postgis.fr contributing to that effort in translating the
> > PostGIS Manual (see section called "Manuels / Livres").
> > regards,
> > ps: Note that only geos 2.1.4 is available by now on portage but you can
> > download more recents versions on : http://gentoo.djayux.net  (for geos
> > is in sci-libs/geos).
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
