[postgis-users] transform question
Don Drake don at drakeconsult.com
Mon Apr 10 19:28:06 PDT 2006
I have map data that I found out is in Old Hawaiian projection, so I tried
transforming some points from WGS84 to Old Hawaiian.
When looking at these transformed points, they're not in the right place.
Here's the output from an example point:
geo=> select astext(transform((geomfromtext('POINT(-157.472827
21.429078)',4326)),4135));
               astext
 POINT(-157.472827 21.4305360069889)
(1 row)
As you can see, the longitude didn't change, just the latitude.     Any
ideas?
geo=> select postgis_full_version();
 POSTGIS="1.1.0" GEOS="2.2.1-CAPI-1.0.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
USE_STATS
(1 row)
-Don
Donald Drake
President
Drake Consulting
http://www.drakeconsult.com/
312-560-1574
800-733-2143
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060410/fcc144a5/attachment.html>
