[postgis-users] line_substring for 0.8.2
strk at refractions.net strk at refractions.net
Tue Apr 11 01:05:29 PDT 2006
You'd need to back-port the function from 1.1.x
Not easy as internal format changed between 0.x and 1.x.
--strk;
On Tue, Apr 11, 2006 at 11:32:15AM +0930, Eric Lam wrote:
> Hello list,
> I would like to use the funtion line_substring(geometry,float,float) on
> a pre postigs 1.x version. Namely version PostGIS 0.8.2. Is there a
> pre-written function which I can use to plug this in?
> thanks in advance
> regards
> Eric Lam
> postgis-users mailing list
