[postgis-users] php query problem "AsText(table.geometry)", multiple schemas
Andreas Neumann neumann at karto.baug.ethz.ch
Thu Apr 13 14:03:01 PDT 2006
Stephen Woodbridge wrote:
> Andreas,
> Do you use different users when connecting from the different clients?
> If you do then you probably need to change the search_path for the
> PHP5 client to include the public schema. It is also possible that
> PHP5 is resetting the search_path but this is likely to be the root of
> the problem.
yes, indeed, I use different users. The user php uses has limited rights
(select only). Do you have an example on how to set the "search_path" in
php? Or is this done within postgresql?
That way I wouldn't have to add the schema name before the function name
and just use the normal SQL statements.
Thank you very much for that hint and any further information on how to
set the search_path.
Andreas
Andreas Neumann
Institute of Cartography
ETH Zurich
Wolfgang-Paulistrasse 15
CH-8093  Zurich, Switzerland
Phone: ++41-44-633 3031, Fax: ++41-44-633 1153
e-mail: neumann at karto.baug.ethz.ch
www: http://www.carto.net/neumann/
SVG.Open: http://www.svgopen.org/
Carto.net: http://www.carto.net/
