[postgis-users] problem to install 1.1.2 on AIX
Patricio Cifuentes Ithal pcifuentes at siigsa.cl
Tue Apr 18 13:15:34 PDT 2006
installing geos 2...
Ingeniero en Informática
Informática
SIIGSA
(56-2) 204 60 22
----- Original Message -----
To: <postgis-users at postgis.refractions.net>
Sent: Tuesday, April 18, 2006 11:26 AM
Subject: [postgis-users] problem to install 1.1.2 on AIX
> Hello all,
> i'm trying to install PostGIS 1.1.2
> over PostgreSQL 8.1.3
> on AIX 5.2 RISC 6000
> the steps
> - gmake
> - gmake install
> are OK
> but when run
> psql -f lwpostgis.sql -d myDB
> had the following result :
>  BEGIN
> psql:/usr/local/postgresql8_1_3/pgsql/share/lwpostgis.sql:45: NOTICE:
type
> "histogram2d" is not yet defined
> DETAIL:  Creating a shell type definition.
> psql:/usr/local/postgresql8_1_3/pgsql/share/lwpostgis.sql:45: ERROR:
could
> not load library "/usr/local/postgresql8_1_3/pgsql/lib/liblwgeom.so":
Cannot
> run a file that does not have a valid format.
> psql:/usr/local/postgresql8_1_3/pgsql/share/lwpostgis.sql:50: ERROR:
> current transaction is aborted, commands ignored until end of transaction
> block
> psql:/usr/local/postgresql8_1_3/pgsql/share/lwpostgis.sql:58: ERROR:
> block
> psql:/usr/local/postgresql8_1_3/pgsql/share/lwpostgis.sql:3358: ERROR:
> block
> ROLLBACK
> Many thanks to anybody that can help me.
> Greetings
> paolo
> postgis-users mailing list
