[postgis-users] postgis for non-superuser user
Shoaib Burq hydromap at gmail.com
Wed Apr 19 16:42:36 PDT 2006
Thanks Markus,
> If you can call "create database", then you actually _are_ superuser, right?
Hummm... not as I understand it. a non-superuser can create db's but
may not be able to create a procedural language or define the C
functions.
> And for installing PostGIS into a database, you need to define some 'C'
> functions. As 'C' is considered an "unsafe" language by PostgreSQL (you
> can bypass the whole security system), you need superuser rights for this.
So the upshot: no-superuser no postgis db? :(
> The debian installation has a template_postgis database, AFAIR.
I wonder if there's anything stopping me from using that on Gentoo?
cheers
shoaib
http://geospatial.nomad-labs.com
