[postgis-users] function from multilinestring to linestring
toni hernnadez thernandez at correo.giscampus.org
Thu Apr 20 07:58:52 PDT 2006
hi Markus,
Up to now I've using the 1.1.1 version of postgis.
Here is the data I've been testing the geomunion with
MULTILINESTRING((498376.89 651569.6,498372.28 651571.89),(498372.28
651571.89,498371.77 651576.05))
a query like the next one is returning a multinestring:
select astext(geomunion(geomfromtext('MULTILINESTRING((498376.89
651569.6,498372.28 651571.89),(498372.28 651571.89,498371.77
651576.05))',23031)))
Eventually I manage to update to postgis 1.1.2 but the databases I was
using do not accept the new funcions (like linemerge)
What am I missing?
Markus Schaber wrote:
>Hi, Toni,
>toni hernnadez wrote:
>>Is there any way to convert a multilinestring object to linestring?
>Not generally, as a LineString contains exactly _one_ sequence of
>connected points, and a MultiLineString can contain more of them.
>For some corner cases (e. G. adjacent or overlapping LineStrings) you
>can try LineMerge() or GeomUnion() to connect the pieces together.
>The first LineString in a MultiLineString can be fetched via
>GeometryN(yourlinestring,1).
>HTH,
>Schabi
