[postgis-users] problems with dpkg-buildpackage on ubuntu 5.10 amd64
alex bodnaru alexbodn at 012.net.il
Fri Apr 21 07:31:31 PDT 2006
hi,
postgis is currently able to be built without need for the whole
postgresql sources.
i would also suggest you take the package on debian gis for a test.
alex
Lorenzo Perone wrote:
> I've followed theese steps:
> "The order that you'll want to build the binary packages is
> proj                          OK
> geos                        OK
> postgresql-8.1          OK
> postgis1"                 NO
> "In order to use the GEOS support, you *may* need to specially compile
> your version of PostgreSQL to link the C++ runtime library.
> To do this, invoke the PgSQL configuration script this way:
> LDFLAGS=-lstdc++ ./configure --your-options-go-here"
> but I couldn't find the right way to do this, whats the file (in the
> compressed archive?) have I to modify?
> I've used this source package:
> http://www.orcaware.com/packages/ubuntu/breezy/postgis1/postgis1_1.0.6.orig.tar.gz
> and then I've applied this pach:
> http://www.orcaware.com/packages/ubuntu/breezy/postgis1/postgis1_1.0.6-0zajac1.diff.gz
> with:
> zcat postgis1_1.0.6-0zajac1.diff.gz | patch -p0
> and then I've moved the folder postgis1-1.0.6 into the build tree:
> /postgresql-8.1-8.1.3/build-tree/postgresql-8.1.3/contrib
> I've tryed to use dpkg-buildpackage -us -uc -rfakeroot 2>&1 | tee
> ../log-PACKAGE_NAME
> but here is the resault:
> /usr/bin/ld: cannot find -lstdc++
> collect2: ld returned 1 exit status
> make[1]: *** [liblwgeom.so.1.0] Error 1
> make[1]: Leaving directory
> `/home/perone/da_compilare/postgresql-8.1-8.1.3/build-tree/postgresql-8.1.3/contrib/postgis1-1.0.6/lwgeom'
> make: *** [liblwgeom] Error 2
> Thanks...
>  Lorenzo
> Lorenzo Perone
> postgis-users mailing list
