[postgis-users] postgis for non-superuser user
alex bodnaru alexbodn at 012.net.il
Sun Apr 23 14:53:23 PDT 2006
right, this is the solution
alex
Shoaib Burq wrote:
> Thanks alex
> I tried the following and it seems to work for me. Can you check if i
> am doing somthing i shouldn't be :)
> cheers
> shoaib
> To create the template in psql run:
> \c template1
> create database template_postgis with template = template1;
> -- set the 'datistemplate' record in the 'pg_database' table for
> 'template_postgis' to TRUE indicating its a template
> UPDATE pg_database SET datistemplate = TRUE where datname = 'template_postgis';
> \c template_postgis
> CREATE LANGUAGE plpgsql ;
> \i /usr/share/postgresql/contrib/lwpostgis.sql;
> \i /usr/share/postgresql/contrib/spatial_ref_sys.sql;
> GRANT ALL ON geometry_columns TO PUBLIC;
> GRANT ALL ON spatial_ref_sys TO PUBLIC;
> -- vacuum freeze: it will guarantee that all rows in the database are
> "frozen" and will not be subject to transaction ID wraparound
> problems.
> VACUUM FREEZE;
> Now non-superuser's can create postgis db's using template_postgis
> createdb -h <host-name> my_gisdb -W -T template_postgis
> On 4/21/06, alex bodnaru <alexbodn at 012.net.il> wrote:
>>hi,
>>i wrote it.
>>please use it.
>>alex
>>Shoaib Burq wrote:
>>>Thanks Markus,
>>>>If you can call "create database", then you actually _are_ superuser, right?
>>>Hummm... not as I understand it. a non-superuser can create db's but
>>>may not be able to create a procedural language or define the C
>>>functions.
>>>>And for installing PostGIS into a database, you need to define some 'C'
>>>>functions. As 'C' is considered an "unsafe" language by PostgreSQL (you
>>>>can bypass the whole security system), you need superuser rights for this.
>>>So the upshot: no-superuser no postgis db? :(
>>>>The debian installation has a template_postgis database, AFAIR.
>>>I wonder if there's anything stopping me from using that on Gentoo?
>>>cheers
>>>shoaib
>>>http://geospatial.nomad-labs.com
>>>_______________________________________________
>>>postgis-users mailing list
>>>postgis-users at postgis.refractions.net
>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
