[postgis-users] Quote problem in query
Stefan Schwarzer stefan.schwarzer at grid.unep.ch
Mon Apr 24 04:59:37 PDT 2006
Hi there,
I just ran into a problem where I can't see and find a way out...
In a php file I have the command (writing the .map file for mapserver
dynamically):
	fwrite($fp, "DATA 'the_geom FROM (SELECT ");
	fwrite($fp, $complex_selection." WHERE table.id = other_table.id) AS
foo USING UNIQUE uid USING srid=-1' ");
Now, I would like to add another WHERE clause, like
	... AND table.name = 'Algeria'
But then I ran into the problem that I have two time the apostrophe,
so the query get's actually truncated at this point:
	fwrite($fp, $complex_selection." WHERE table.id = other_table.id AND
table.name = '
Error message naturally then.
Is there any way to use magic quotes or something similar to "mimic"
the apostrophe for the country name clause?
Thanks for any hints.
