[postgis-users] "Undefined symbol: nth" errors when adding lwpostgis.sql to postgre 8.1.3
Michael Thadani michael.thadani at rlmgroup.com.au
Tue Apr 25 18:05:40 PDT 2006
Hi there,
I am trying to install postgis on an installation of PostgresSQL 8.1.3.
I installed postgres from source and the automated test performs without
errors. I also downloaded the GEOS and PROJ libraries and installed them
as directed (./configure, make, make install).
I followed the instructions on installing postgis (again, ./configure,
make, make install) but when attempting to add the lwpostgis.sql file, I
receive a slew of errors.
Originally my attempts to use this file produced
>NOTICE:  type "histogram2d" is not yet defined
>DETAIL:  Creating a shell type definition.
>ERROR:  could not access file "$libdir/liblwgeom.so.1.1": No such file
or directory
However, after sed'ing the sql to replace $libdir with my pgsql
directory I now receive
>ERROR:  could not load library "/usr/lib64/pgsql/liblwgeom.so.1.1":
/usr/lib64/pgsql/liblwgeom.so.1.1: undefined symbol: nth
I noticed that someone else had encountered this issue before
(http://postgis.refractions.net/pipermail/postgis-devel/2006-February/00
1977.html) but have been unable to find information about how to resolve
it.
For reference, I am installing on RH Enterprise Linux 3.
The details of ./configure from postgis are
>SUMMARY
> HOST_OS: linux-gnu
>   PGSQL: /usr/local/pgsql/bin/pg_config
>    GEOS: /usr/local/bin/geos-config (with C-API)
>    PROJ: dir=/usr/local
>   ICONV: 1
> PORTNAME: linux
>   PREFIX: /usr/local/pgsql
>  EPREFIX: ${prefix}
>      DOC: /usr/local/pgsql/doc/contrib
>     DATA: /usr/local/pgsql/share/contrib
>      MAN: /usr/local/pgsql/man
>      BIN: /usr/local/pgsql/bin
>      EXT: /usr/local/pgsql/lib (\$$libdir)
The output from pg_config is
[mthadani at localhost postgis-1.1.2]$ pg_config
>BINDIR = /usr/local/pgsql/bin
>DOCDIR = /usr/local/pgsql/doc
>INCLUDEDIR = /usr/local/pgsql/include
>PKGINCLUDEDIR = /usr/local/pgsql/include
>INCLUDEDIR-SERVER = /usr/local/pgsql/include/server
>LIBDIR = /usr/local/pgsql/lib
>PKGLIBDIR = /usr/local/pgsql/lib
>LOCALEDIR =
>MANDIR = /usr/local/pgsql/man
>SHAREDIR = /usr/local/pgsql/share
>SYSCONFDIR = /usr/local/pgsql/etc
>PGXS = /usr/local/pgsql/lib/pgxs/src/makefiles/pgxs.mk
>CONFIGURE =
>CC = gcc
>CPPFLAGS = -D_GNU_SOURCE
>CFLAGS = -O2 -Wall -Wmissing-prototypes -Wpointer-arith -Winline
-Wdeclaration-after-statement -fno-strict-aliasing
>CFLAGS_SL = -fpic
>LDFLAGS = -Wl,-rpath,/usr/local/pgsql/lib
>LDFLAGS_SL =
>LIBS = -lpgport -lz -lreadline -ltermcap -lcrypt -lresolv -lnsl -ldl
-lm -lbsd
>VERSION = PostgreSQL 8.1.3
Thanks
Michael Thadani
Graduate Software Engineer
RLM Systems Pty. Ltd.
Email: michael.thadani at rlmgroup.com.au
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060426/56c141fe/attachment.html>
