[postgis-users] Re: PostGIS setup - Ubuntu Breezy + PostgreSQL-8.1
Eduardo Luís Garcia Escovar eduardo.escovar at 3wt.com.br
Thu Apr 27 08:50:23 PDT 2006
Randy,
Please read the documentation:
http://postgis.refractions.net/docs/ch02.html#PGInstall
Maybe if you use the LDFLAGS option (see "Note" in the URL above), then
it will work.
Hope it helps,
Eduardo
Randy Burkhardt escreveu:
> randy at kubuntu:~/postgresql-8.1.3/contrib/postgis-1.1.2$ sudo make
> Password:
> make -C lwgeom
> make[1]: Entering directory
> `/home/randy/postgresql-8.1.3/contrib/postgis-1.1.2/lwgeom'
> sh ../geos_version.sh /usr > postgis_geos_version.h
> gcc -DUSE_VERSION=81 -DPOSTGIS_LIB_VERSION='"1.1.2"'
> -DPOSTGIS_VERSION='"1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"'
> -DPOSTGIS_SCRIPTS_VERSION='"1.1.2"' -DPOSTGIS_BUILD_DATE='"2006-04-27
> 15:37:08"' -I/usr/include -DUSE_PROJ
> -I/usr/include/postgresql/8.1/server -DAUTOCACHE_BBOX=1  -DUSE_STATS
> -Wall -g -O2 -fPIC -fexceptions -DUSE_GEOS    -c -o liblwgeom.o
> liblwgeom.c
> In file included from liblwgeom.c:26:
> lwgeom_pg.h:4:22: error: postgres.h: No such file or directory
> lwgeom_pg.h:5:29: error: utils/geo_decls.h: No such file or directory
> lwgeom_pg.h:6:18: error: fmgr.h: No such file or directory
> lwgeom_pg.h:36: error: syntax error before 'getGeometryOID'
> lwgeom_pg.h:36: warning: type defaults to 'int' in declaration of
> 'getGeometryOID'
> lwgeom_pg.h:36: warning: data definition has no type or storage class
> lwgeom_pg.h:43: error: syntax error before '*' token
> and a hundred more errors and warnings
> Would you tell me what to do here?
> Thanks
> On 4/27/06, Randy Burkhardt <randy.burkhardt at gmail.com> wrote:
>> I'm still getting that error, sorry to bother you guys with this install
>> situation.  I've GEOS installed but 'make' postgis-1.1.2 still gives those
>> same errors I sampled above.
>> Can I get a bit of more help?
>> Thank you
>> On 4/26/06, Randy Burkhardt <randy.burkhardt at gmail.com> wrote:
>>> Thanks, I thought I had done that, but you remind me I may have to get
>>> the sequence of installations more workable.
>>> On 4/26/06, Patricio Cifuentes Ithal <pcifuentes at siigsa.cl > wrote:
>>>> installing GEOS first
>>>> Ingeniero en Informática
>>>> Informática
>>>> SIIGSA
>>>> (56-2) 204 60 22
>>>> ----- Original Message -----
>>>> From: "Randy Burkhardt" <randy.burkhardt at gmail.com>
>>>> To: "PostGIS Users Discussion" < postgis-users at postgis.refractions.net>
>>>> Sent: Wednesday, April 26, 2006 1:37 PM
>>>> Subject: [postgis-users] Re: PostGIS setup - Ubuntu Breezy +
>>> PostgreSQL-8.1
>>>>> Hello Paul Scott and guys,
>>>>> I've been using your wiki page here to try to install postgis1.1.2 on
>>>>> Kubuntu (instead of Uxxxxx).
>>>>> at 'make' in postgis1.1.2 I'm getting
>>>>> liblwgeom.c:167: warning: incompatible implicit declaration of
>>>>> built-in function 'strlen'
>>>>> make[1]: *** [liblwgeom.o] Error 1
>>>>> make[1]: Leaving directory
>>>>> make: *** [liblwgeom] Error
>>>>> I've got postgis-1.1.2 in /home/randy/postgresql-8.1.3/contrib/ and
>>>>> things seem ok except for this make error as make tries to work on
>>>>> liblwgeom and lwgeom.
>>>>> My latest try was to install all versions of automake, but that
>> didn't
>>>>> do the trick.
>>>>> Can i get a suggestion on my next steps to help get 'make' to
>>> continue?
>>>>> Thanks, Mr. Scott, by the way for sharing your work on the wiki page,
>>>>> it's been very helpful to me.
>>>>> On 4/17/06, Paul Scott <pscott at uwc.ac.za> wrote:
>>>>>> I have just completed a setup of PostGIS-1.1.2 with
>> PostgreSQL-8.1on
>>>>>> Ubuntu Breezy 5.10 GNU/linux. I articled the steps on
>> http://fsiu.uwc.ac.za/gis/index.php?module=wiki&action=wikilink&pagename=PostGisInstallUbuntu
>>>>>> for anyone interested.
>>>>>> --Paul
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
3WT - Wireless Web World Tech
eduardo.escovar at 3WT.com.br
tel: +55 16 3371-7761
fax: +55 16 3371-9847
