[postgis-users] Re: PostGIS setup - Ubuntu Breezy + PostgreSQL-8.1
Randy Burkhardt randy.burkhardt at gmail.com
Thu Apr 27 09:32:58 PDT 2006
st
On 4/27/06, Eduardo Luís Garcia Escovar <eduardo.escovar at 3wt.com.br> wrote:
> Randy,
> Please read the documentation:
> http://postgis.refractions.net/docs/ch02.html#PGInstall
> Maybe if you use the LDFLAGS option (see "Note" in the URL above), then
> it will work.
> Hope it helps,
> Eduardo
> Randy Burkhardt escreveu:
> > randy at kubuntu:~/postgresql-8.1.3/contrib/postgis-1.1.2$ sudo make
> > Password:
> > make -C lwgeom
> > make[1]: Entering directory
> > `/home/randy/postgresql-8.1.3/contrib/postgis-1.1.2/lwgeom'
> > sh ../geos_version.sh /usr > postgis_geos_version.h
> > gcc -DUSE_VERSION=81 -DPOSTGIS_LIB_VERSION='"1.1.2"'
> > -DPOSTGIS_VERSION='" 1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"'
> > -DPOSTGIS_SCRIPTS_VERSION='"1.1.2"' -DPOSTGIS_BUILD_DATE='"2006-04-27
> > 15:37:08"' -I/usr/include -DUSE_PROJ
> > -I/usr/include/postgresql/8.1/server -DAUTOCACHE_BBOX=1  -DUSE_STATS
> > -Wall -g -O2 -fPIC -fexceptions -DUSE_GEOS    -c -o liblwgeom.o
> > liblwgeom.c
> > In file included from liblwgeom.c:26:
> > lwgeom_pg.h:4:22: error: postgres.h: No such file or directory
> > lwgeom_pg.h:5:29: error: utils/geo_decls.h: No such file or directory
> > lwgeom_pg.h:6:18: error: fmgr.h: No such file or directory
> > lwgeom_pg.h:36: error: syntax error before 'getGeometryOID'
> > lwgeom_pg.h:36: warning: type defaults to 'int' in declaration of
> > 'getGeometryOID'
> > lwgeom_pg.h:36: warning: data definition has no type or storage class
> > lwgeom_pg.h:43: error: syntax error before '*' token
> > and a hundred more errors and warnings
> > Would you tell me what to do here?
> > Thanks
> > On 4/27/06, Randy Burkhardt <randy.burkhardt at gmail.com> wrote:
> >> I'm still getting that error, sorry to bother you guys with this
> install
> >> situation.  I've GEOS installed but 'make' postgis-1.1.2 still gives
> those
> >> same errors I sampled above.
> >> Can I get a bit of more help?
> >> Thank you
> >> On 4/26/06, Randy Burkhardt <randy.burkhardt at gmail.com> wrote:
> >>> Thanks, I thought I had done that, but you remind me I may have to get
> >>> the sequence of installations more workable.
> >>> On 4/26/06, Patricio Cifuentes Ithal <pcifuentes at siigsa.cl > wrote:
> >>>> installing GEOS first
> >>>> Ingeniero en Informática
> >>>> Informática
> >>>> SIIGSA
> >>>> (56-2) 204 60 22
> >>>> ----- Original Message -----
> >>>> From: "Randy Burkhardt" <randy.burkhardt at gmail.com >
> >>>> To: "PostGIS Users Discussion" <
> postgis-users at postgis.refractions.net>
> >>>> Sent: Wednesday, April 26, 2006 1:37 PM
> >>>> Subject: [postgis-users] Re: PostGIS setup - Ubuntu Breezy +
> >>> PostgreSQL-8.1
> >>>>> Hello Paul Scott and guys,
> >>>>> I've been using your wiki page here to try to install postgis1.1.2on
> >>>>> Kubuntu (instead of Uxxxxx).
> >>>>> at 'make' in postgis1.1.2 I'm getting
> >>>>> liblwgeom.c:167: warning: incompatible implicit declaration of
> >>>>> built-in function 'strlen'
> >>>>> make[1]: *** [liblwgeom.o] Error 1
> >>>>> make[1]: Leaving directory
> >>>>> make: *** [liblwgeom] Error
> >>>>> I've got postgis-1.1.2 in /home/randy/postgresql- 8.1.3/contrib/ and
> >>>>> things seem ok except for this make error as make tries to work on
> >>>>> liblwgeom and lwgeom.
> >>>>> My latest try was to install all versions of automake, but that
> >> didn't
> >>>>> do the trick.
> >>>>> Can i get a suggestion on my next steps to help get 'make' to
> >>> continue?
> >>>>> Thanks, Mr. Scott, by the way for sharing your work on the wiki
> page,
> >>>>> it's been very helpful to me.
> >>>>> On 4/17/06, Paul Scott < pscott at uwc.ac.za> wrote:
> >>>>>> I have just completed a setup of PostGIS-1.1.2 with
> >> PostgreSQL-8.1on
> >>>>>> Ubuntu Breezy 5.10 GNU/linux. I articled the steps on
> http://fsiu.uwc.ac.za/gis/index.php?module=wiki&action=wikilink&pagename=PostGisInstallUbuntu
> >>>>>> for anyone interested.
> >>>>>> --Paul
> >>>>>> _______________________________________________
> >>>>>> postgis-users mailing list
> >>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> 3WT - Wireless Web World Tech
> eduardo.escovar at 3WT.com.br
> tel: +55 16 3371-7761
> fax: +55 16 3371-9847
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060427/4e238700/attachment.html>
