[postgis-users] Re: PostGIS setup - Ubuntu Breezy + PostgreSQL-8.1
Randy Burkhardt randy.burkhardt at gmail.com
Fri Apr 28 08:17:52 PDT 2006
Hearing no objections?
On 4/27/06, Randy Burkhardt <randy.burkhardt at gmail.com> wrote:
> Thanks guys
> Now I'm starting with fresh clean Kubuntu 5.10 breezy install.
> I believe Paul's list of tools and libs should come first, generally
> speaking.
> But should the main order of the major components be?
> postgresql-8.1.3
> geos-2.2.1
> proj-4.4.9       proj-4.4.9d-2     <--deb?
> postgis-1.1.2
> What do you think guys?
> When I come back from work later I would like to determine the ./configure
> parameters, if we have the components versions and order correctly selected.
> Thank you
> On 4/27/06, Patricio Cifuentes Ithal <pcifuentes at siigsa.cl> wrote:
> > install postgres firts, pg_config only exist if installing postgres
> > Ingeniero en Informática
> > Informática
> > SIIGSA
> > (56-2) 204 60 22
> > ----- Original Message -----
> > From: < strk at refractions.net>
> > To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> > Sent: Thursday, April 27, 2006 12:40 PM
> > Subject: Re: [postgis-users] Re: PostGIS setup - Ubuntu Breezy +
> > PostgreSQL-8.1
> > > On Thu, Apr 27, 2006 at 09:32:24AM -0700, Randy Burkhardt wrote:
> > > > pg_config --includedir-server  returns
> > > > /usr/include/postgrsql/8.1/server
> > > > however I find 'postgres.h' these 3 places
> > > > usr/local/pgsql/include/server/
> > > > usr/include/postgresql/
> > > > home/randy/postgresql-8.1.3/src/include/
> > > Your installation is pretty screwed up Randy.
> > > You probably have more then one pg_config, at
> > > least one for each postgres.h you found.
> > > If you handle to find it pass it to PostGIS (not GEOS)
> > > configure script:
> > > For example:
> > > ./configure --with-pgsql=/usr/local/pgsql/bin/pg_config
> > > --strk;
> > > _______________________________________________
> > > postgis-users mailing list
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060428/afd78371/attachment.html>
