[postgis-users] Parse error - Invalid geometry in function
Sylvain Racine syracine at sympatico.ca
Fri Aug 4 04:48:59 PDT 2006
Hello,
I wrote a function who looks up in an address table and records it if
not. I have a problem with INSERT INTO statement. When I do it alone, it
works fine. But if I use it inside a function (using variables) while I
want to enter a new address, I got a 'parse error - invalid geometry'.
Is anyone can help me?
CREATE TABLE adresses (
     id    integer    PRIMARY KEY DEFAULT nextval('seq_adresse'),
SELECT AddGeometryColumn('greffe1','adresses','geom', 4269, 'POINT', 2);
CREATE FUNCTION getCache(varchar)
	RETURNS SETOF integer AS '
	SELECT id FROM adresses WHERE adresse = $1;
' LANGUAGE sql;
CREATE FUNCTION getGeocode (varchar,varchar,varchar)
	RETURNS integer AS '
DECLARE
	_adresse ALIAS FOR $1;
	_lon ALIAS FOR $2;
	_lat ALIAS FOR $3;
	getCache RECORD;
BEGIN
	SELECT INTO getCache * FROM getCache(_adresse);
	IF NOT FOUND THEN
		INSERT INTO adresses(adresse,geom)
		  VALUES (_adresse, GeometryFromText(\'POINT(_lon _lat)\',4269));
		return currval(\'seq_adresse\');
	ELSE
		return getCache.getCache;
	END IF;
END;
' LANGUAGE plpgsql;
The error occurs while I do:
SELECT * FROM getGeocode ('20, RUE DE L\'ESCAULT, ST-ÉTIENNE,
QC','-71.31453037261963','46.649259404968');
where this address not exists inside the "adresses" table.
But
INSERT INTO
VALUES ('20, RUE DE L\'ESCAULT, ST-ÉTIENNE, QC',
GeometryFromText('POINT(-71.31453037261963 46.649259404968)',4269));
works fine...
Best regards
Sylvain Racine
