[postgis-users] getting non-latlon extent as lat/lon
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Sat Aug 5 07:17:54 PDT 2006
On Sat, 2006-08-05 at 05:03 -0700, Steve Benzo wrote:
> Ok, that seems to get me a bunch of lat/lon coordinates, but how do I
> translate those into an extent then? Thanks.
> SB
Hi Steve,
How about something like this:
SELECT AsText(transform(extent(the_geom), 4326) FROM geomtable;
Note that since extent() is an aggregate it will scan the entire table
to produce the overall extent which can be slow on larger tables; you
may like to consider using the estimated_extent() function if you need
to do this interactively as part of an application.
Kind regards,
Mark.
