[postgis-users] Re: SRID for USA_Lambert_Conformal_Conic
P Kishor punkish at eidesis.org
Sat Aug 19 16:43:05 PDT 2006
Actually, I should explain this a bit further --
(a) I had a Shapefile in USA_Lambert_Conformal_Conic that I imported
into PostGIS using the shp2pgsql, psql dance. Whatever I did, its SRID
is set to -1.
(b) I created another dataset from lon/lat explicitly setting its SRID to 4326.
Of course, now I can't do any geometrical analysis on these two
because they are in different spatial references. Ideally, I want to
convert my (b) dataset, the points that are in 4326, to the same srs
as (a) dataset, namely USA_Lambert_Conformal_Conic.
Hence my question.
Many thanks in advance.
On 8/19/06, P Kishor <punkish at eidesis.org> wrote:
> This is a topic I know very little about. Where do I learn more about
> SRIDs, and more specifically,
> 1. how do I find SRID for USA_Lambert_Conformal_Conic; and
> 2. use that to change a dataset (project? is that the word wrt SRIDs?)
Puneet Kishor http://punkish.eidesis.org/
Nelson Inst. for Env. Studies, UW-Madison http://www.ies.wisc.edu/
Open Source Geospatial Foundation https://edu.osgeo.org/
