[postgis-users] Failing: psql -d [yourdatabase] -f lwpostgis.sql
Adam adam at spatialsystems.org
Fri Dec 29 11:51:23 PST 2006
I'm installing version 1.1.6 and everything is fine until the step:
It's all erroring out.  Any idea what the problem is or where I go to see what the error is?
psql:lwpostgis.sql:3368: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3375: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3380: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3385: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3444: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3462: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3509: ERROR:  current transaction is aborted, commands ignored until end of transaction block
ROLLBACK
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061229/b717d060/attachment.html>
