[postgis-users] liblwgeom.1.1.so - Error installing PostGIS
Christian Heine christian at geosci.usyd.edu.au
Tue Feb 7 03:15:47 PST 2006
Hi strk,
thanks for the reply - I was just about to write another message to
the list explaining the problems I experience:
I made a clean install today just to double check if I did something
wrong yesterday:
- geos version 2.2.1 from source (no special configure flags)
- postgresql version 8.1.2 from source
- postgis version 1.1.1 from source (no special configure flags)
(used the existing proj 4.4.9)
After compiling everything and setting up a new database I tried to
load postgis - different error as yesterday but still related to a
missing symbol in the liblwgeom.1.1.so library:
$ psql icons < lwpostgis.sql
BEGIN
NOTICE:  type "histogram2d" is not yet defined
DETAIL:  Creating a shell type definition.
ERROR:  could not load library "/usr/local/pgsql/lib/liblwgeom.
1.1.so": Symbol not found: _MemoryContextSwitchTo
   Referenced from: /usr/local/pgsql/lib/liblwgeom.1.1.so
   Expected in: flat namespace
Ok, deleted everything (incl the geos libraries) and installed the
pre-compiled stuff (libraries + postgresl 8.1.2 + postgis 1.1.1) from
http://www.kyngchaos.com/macosx/downloads.php:
- postgis loads correctly but when I try using the "geomfromewkt"
function I get:
ERROR:  function geomfromewkt("unknown", integer) does not exist
HINT:  No function matches the given name and argument types. You may
need to add explicit type casts.
As I can recall from some of my work, geomfromewkt has been working
fine with postgresql 8.0.3 and postgis 1.0.0. The stuff I tried to
load was from an earlier mail to this list: Elwood Cordery: "[postgis-
users] RE: HELP 3d spatial bounding box" and some of simple polygons
I created myself.
> Try running make clean and make again, it could be
> you had old geos headers laying around.
Ok, I will give it a go.
> Please show last lines of ./configure.
HOST_OS: darwin8.4.0
    PGSQL: /usr/local/pgsql/bin/pg_config
     GEOS: /usr/local/bin/geos-config (with C-API)
     PROJ: dir=/usr/local
    ICONV: 1 -liconv
PORTNAME: darwin
    PREFIX: /usr/local/pgsql
   EPREFIX: ${prefix}
       DOC: /usr/local/pgsql/doc/contrib
      DATA: /usr/local/pgsql/share/contrib
       MAN: /usr/local/pgsql/man
       BIN: /usr/local/pgsql/bin
       EXT: /usr/local/pgsql/lib (\$$libdir)
> Also, where did you install libgeos from ?
I installed geos from source today - version 2.2.1 - see above
> And what's the output of geos-config --version ?
2.2.1
Grateful for _any_ feedback!
Chris
OS: Mac OS X 10.4.4 on Dual G5
>>> Is 1.1.so dynamically linked against libgeos?
>>> What does ldd say ?
>> On Mac OS X there's no ldd - instead "otool -L":
>> $ otool -L /usr/local/pgsql/lib/liblwgeom.1.1.so
>> /usr/local/pgsql/lib/liblwgeom.1.1.so:
>>     /usr/lib/libstdc++.6.dylib (compatibility version 7.0.0, current
>>     version 7.3.0)
>>     /usr/local/lib/libgeos.2.dylib (compatibility version 4.0.0,
>> current
>>     version 4.1.0)
>>     /usr/local/lib/libproj.0.dylib (compatibility version 6.0.0,
>> current
>>     version 6.0.0)
>>     /usr/lib/libmx.A.dylib (compatibility version 1.0.0, current
>> version
>>     92.0.0)
>>     /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current
>>     version 88.1.2)
>> Chris
>>> On Mon, Feb 06, 2006 at 02:53:23PM +1100, Christian Heine wrote:
>>>> Dear all,
>>>> following up on my earlier mail "Error installing PostGIS-1.1.1" I
>>>> tried tracking down the error and running nm (display name list)
>>>> gave
>>>> the following result:
>>>> 00094668 s __ZTIN4geos13GEOSExceptionE
>>>> 0009462c s __ZTIPN4geos13GEOSExceptionE
>>>> 00094670 s __ZTSN4geos13GEOSExceptionE
>>>> 00094650 s __ZTSPN4geos13GEOSExceptionE
>>>> /usr/local/pgsql/lib/liblwgeom.1.0.so
>>>>         U __ZTIN4geos13GEOSExceptionE
>>>> 000477b0 S __ZTIPN4geos13GEOSExceptionE
>>>> 0003f4b8 S __ZTSPN4geos13GEOSExceptionE
>>>> /usr/local/pgsql/lib/liblwgeom.1.so
>>>> /usr/local/pgsql/lib/liblwgeom.so
>>>> /usr/local/pgsql/lib/liblwgeom.so.1
>>>> That seems to indicate that __ZTIN4geos13GEOSExceptionE symbol is
>>>> undefined in liblwgeom.1.1.so, liblwgeom.1.so and liblwgeom.so,
>>>> whereas it is defined in liblwgeom.1.0.so and liblwgeom.so.1
>>>> Is there a way to fix this?
>>>> Cheers,
>>>> Chris
>>>> OS: Mac OS X 10.4.4 on a Dual G5 (64bit), PostgreSQL 8.0.3
