[postgis-users] problem to install postgis-1.1.1
Paolo De Simone pdesimone at infocall.it
Thu Feb 16 04:05:18 PST 2006
Dear all,
my problem is to run
    the make command
in order to install postgis-1.1.1
(environment O.S.   AIX 5.1 on RISC , PostgreSQL 7.4.3)
I have run
    ./configure
and the result is ok
but the make command returns the message:
[:-)]# make
Using GNU make found at /usr/bin/gmake
/usr/bin/gmake -C lwgeom
gmake[1]: Entering directory `/usr/local/pgsql/contrib/postgis-1.1.1/lwgeom'
ar  liblwgeom.a measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o
lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o wktunparse.o
lwgparse.o wktparse.tab.o lex.yy.o vsprintf.o liblwgeom.o lwgeom_pg.o
lwgeom_debug.o lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o
lwgeom_geos_c.o lwgeom_inout.o lwgeom_estimate.o lwgeom_functions_basic.o
lwgeom_gist.o lwgeom_btree.o lwgeom_transform.o stringBuffer.o lwgeom_box.o
lwgeom_box3d.o lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o
lwgeom_triggers.o lwgeom_dump.o lwgeom_functions_lrs.o
ar: 0707-101 e is not a valid flag.
gmake[1]: *** [liblwgeom.a] Error 1
gmake[1]: Leaving directory `/usr/local/pgsql/contrib/postgis-1.1.1/lwgeom'
gmake: *** [liblwgeom] Error 2
make: 1254-004 The error code from the last command is 2.
Stop.
Any ideas?
Thanks in advance,
Paolo
thank you
