[postgis-users] Writing to PostGIS with OGR
Thu Feb 16 05:38:13 PST 2006
Philippe Wüger wrote:
> Ok, I didn't know I couldn't set features which were ExecuteSQL() result
> sets. I changed the program to use GetLayerByName(). SetFeature() now
> prints Messages like this: "OGR_PG: PQexec(DELETE FROM "str" WHERE
> "ogc_fid" = 64696)". Is this what I am supposed to see if features get set?
Philippe,
Yes, that should show up in debug mode.  OGR's PG driver does SetFeature()
by deleting the existing row, and then re-creating it rather than trying
to use UPDATE.
> Unfortunately, I now get an "EXC_BAD_ACCESS" signal during  execution of
> the program. If I run it with ExecuteSQL() I don't get that error.
Well, the bad access is definitely not supposed to happen.  If you are in
a position to debug things, that would be very helpful.  If not, perhaps
we can figure out how I can reproduce the problem here.
Best regards,
