[postgis-users] Datum Change
Armin Burger armin.burger at gmx.net
Fri Feb 17 15:05:17 PST 2006
Jaime,
you need to add the parameters for the datum shift to your
spatial_ref_sys table in the proj4text field as '+towgs84=' parameter
for all projections where you want to have the datum shift. I guess the
reason why these parameters are not added by default is that you can
have different sets per projection system, depending on the region.
A short list for some projections is available at
http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass/src/libes/gis/datumtransform.table
for Europe you can find parameters eg. at
http://crs.bkg.bund.de/crs-eu/
And the EPSG database (at www.epsg.org) has also a bigger set of those
parameters. There was once a posting of somebody on this list providing
additional tables and views to extract the information from the EPSG tables.
Armin
jaime villanueva wrote:
> Hi list users
> How can i make Datum transformations with postgis?
> i have tried with transform function, with diferents SRID's, but the
> reproyection works fine (transform() function using srid's with the same
> datum), but the transformation between different DATUMS give me wrong
> coordinates.
> Regards
> postgis-users mailing list
