[postgis-users] insert into a geometry field from 4gl
Paul Ramsey pramsey at refractions.net
Wed Feb 22 11:08:56 PST 2006
Fay,
geomfromtext() is a function.  In preparing your statement ahead of
time, then executing into it, the cursor is probably treating the
value you stick in as a string literal instead, which is not a valid
geometry.  Try just doing this:
  LET sql_stmt = "INSERT INTO gps_log  (uid,geom_pt) Values (?,?)"
  PREPARE insert_gps_tb FROM sql_stmt
  LET Uid=”test”
  LET gps_point = “POINT(1870391 320462)”
  EXECUTE insert_gps_tb USING uid, gps_point
The geom_in function in PostGIS should hopefully automagically figure
out the right thing to do.
P.
On 22-Feb-06, at 9:33 AM, Fay Du wrote:
> Hi all:
> I have to insert from 4gl to a postgresql database. What I did in
> postGIS is:
> INSERT INTO gps_log (uid, geom_pt) values ('test1', geomfromtext
> ('POINT(1870391 320462)',-1));
>     It works perfect.
> In 4gl,  I did followings:
>   -- initialize insert into gps log table cursor
> LET Uid=”test”
> LET gps_point = “geomfromtext('POINT(1870391 320462)',-1)”
> I got error -6372.
>  Thanks in advance for any help
> Fay
> postgis-users mailing list
