[postgis-users] intersection and geometrycollection
    Emilia Venturato
    venturato at faunalia.it
    Wed Jan  4 09:09:57 PST 2006
Sorry for message's object, the problem is with polygon not with
geometrycollection.
Lia
I need to extract the intersection between two geometry fields (polygon,
polygon).
I used Intersection(geometry, geometry).
The results are polygons which I would like to see in QuantumGIS.
But qgis crash and error is: sql=Segmentation fault.
I tried also to export as shapefile (pgsql2shp) but just .dbf was created.
Geometries are valid, simple and the geometry (looked as text) seems right.
Have you any idea?
Could you help me?
Thanks
Lia
(Emi)Lia Venturato
venturato at faunalia.it    venturato at jabber.org    www.faunalia.it
Piazza Garibaldi 4 56025 Pontedera (PI)  Italy
Tel: (+39) 347-2770007 Fax (+39) 0587-213742
Linux User: 388585 http://counter.li.org
