Antw: [postgis-users] load shapefile to postgis with SRIDproblem
Barend Köbben kobben at itc.nl
Fri Jan 6 02:40:20 PST 2006
It's surely not only important for re-projection. It is important in any case where you care about the fact that your coordinates are not mere numbers, but have a specific relation (=the projection and datum=srid).
For instance if you want to calculate distances and areas, or simply wnat to map them at a certain scale, you need to know what the numbers are in fact depicting...
____________________________
Barend Köbben
International Institute for Geo-information Sciences and  Earth Observation (ITC)
PO Box 6, 7500AA Enschede (The Netherlands)
ph: +31-(0)534874253; fax: +31-(0)534874335
_____________________________
From: postgis-users-bounces at postgis.refractions.net on behalf of Jürgen Mischker
Sent: Fri 06.01.2006 11:01
To: postgis-users at postgis.refractions.net
Subject: Antw: [postgis-users] load shapefile to postgis with SRIDproblem
hi kurt - using --srid is not essential for loading shp into postgis and doing some spatial analysis with these data.
in my oppinion it is only important while re-projection. you also can add/change the  projection  of an exsisting postgis relation using the UpdateGeometrySRID() function later on.
good luck
juergen
>>> mtrp36 at hotmail.com 06.01.06 0.38 >>>
I am new to postgis and  have questions regarding SRID while loading
shapefile to postgis.
I have a shapefile which is Maryland US and I would like to load it to
postgis. What is the difference of using shp2pgsql with/without -s<SRID>
option? Is it only important while re-projection or it's essential for
creating database? Thanks
Kurt
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060106/1b9b4ec0/attachment.bin>
