[postgis-users] AddGeometryColumn() Question
Stephen Woodbridge woodbri at swoodbridge.com
Fri Jan 6 11:21:03 PST 2006
strk at refractions.net wrote:
> On Fri, Jan 06, 2006 at 09:54:06AM -0500, Stephen Woodbridge wrote:
>>Hi all,
>>When a create a table using
>>CREATE TABLE foobar AS SELECT ...
>>SELECT * INTO TABLE foobar ...
>>The metadata and constraints that are created by AddGeometryColumn() are
>>not created.
>>What is the correct way to do this?
> Create with AddGeometryColumn, then INSERT INTO .. SELECT .. FROM ..
>>Can I use AddGeometryColumn() and specify the existing column in the new
>>table?
> Nope :(
>>Does it have the smarts to check if it already exists and continue only
>>updating the missing information and constraints?
> No, it's dumb. I was thinking about this when working on topology support.
> SQL/MM specs use a "santifier" function for this (read: use existing thing
> making it a "special" thing), while AddGeometryColumn insists on creating
> it.
>>Would it make sense to make it behave like this? exactly for this purpose?
> Good question, what other people think ?
I like the idea of having a SanctifyGeometyColumn() or
BlessGeometryColumn() to bless a column that was created via means other
than AddGeometryColumn() which is not always the "best" way to create
the table.
I am building a process to delete and reload vendor data on a quarterly
basis from a table that has multiple data sets merged into it. We do
this by copying an existing production table doing the updates to it
then swap it into production.
-Steve
