[postgis-users] OT: pgsql2shp temporary table persists (avpgcon)
Robert Burgholzer rburghol at chesapeakebay.net
Fri Jan 6 11:30:50 PST 2006
More Info:
The "vacuum full" did not succeed in removing the phantom table, my problems with shp2pgsql from the command line persist as well.
________________________________________
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Robert Burgholzer
Sent: Friday, January 06, 2006 2:02 PM
To: PostGIS Users Discussion
Subject: [postgis-users] OT: pgsql2shp temporary table persists (avpgcon)
I ran into a problem running avpgcon --I managed to goof up my db somehow, I think cancelling a pgsql2shp query at a bad time. Although this problem occurred using avpgcon, I believe that the source of the problem may lie in the shp2pgsql routine somehow.
Now, when opening up the avpgcon add theme dialog a phantom table shows up in the list named "__pgsql2shp_tmp_table". Whenever I try to load a shape from this database it fails, and the postgres error console shows it asking for one of the columns in this phantom table, regardless of the table I am actually asking for.  This even happens when using p2sql2shp from the command line regardless of the query I put in.  It shows up in multiple clients (2 different workstations) and seems to affect only this database. I can load things fine from other databases.  I have restarted my postmaster process to no avail, and am currently performing a "vacuum full" in hopes that this will solve it.
I will report back if this solves the problem, but I am thinking this may be an obscure bug in the shp2pgsql routine. Any clues?
thanks
Robert W. Burgholzer
Nonpoint Source Data Analyst
University of Maryland, College Park
Chesapeake Bay Program Office
410 Severn Avenue, Suite 305B
Annapolis, MD, 21403
Phone: (410) 267-5779
http://www.chesapeakebay.net/
