[postgis-users] OT: pgsql2shp temporary table persists (avpgcon)
strk at refractions.net strk at refractions.net
Sun Jan 8 05:27:38 PST 2006
It seems a bug of postgresql, which where unable to
recover from a crash.
__pgsql2shp_tmp_table is a temporary table and should
be dropped at session end.
--strk;
On Fri, Jan 06, 2006 at 03:15:43PM -0500, Robert Burgholzer wrote:
> Sometimes all you need is someone to listen ...I  managed to solve the problem as follows:
> The table was somehow stuck in the system table "pg_class".  Just had to delete it from there, using the following query:
> delete from pg_class where relname = '__pgsql2shp_tmp_table';
> Now, I don't know if this was an advisable way to handle this or not, but it seemed to work. Pgsql2shp now behaves as it did before my ill-fated cancellation.
> Anyone have an opinion as to whether this is a bug or not?
> Robert
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Robert Burgholzer
> Sent: Friday, January 06, 2006 2:31 PM
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] OT: pgsql2shp temporary table persists (avpgcon)
> More Info:
> The "vacuum full" did not succeed in removing the phantom table, my problems with shp2pgsql from the command line persist as well.
> ________________________________________
> Sent: Friday, January 06, 2006 2:02 PM
> Subject: [postgis-users] OT: pgsql2shp temporary table persists (avpgcon)
> I ran into a problem running avpgcon --I managed to goof up my db somehow, I think cancelling a pgsql2shp query at a bad time. Although this problem occurred using avpgcon, I believe that the source of the problem may lie in the shp2pgsql routine somehow.
> Now, when opening up the avpgcon add theme dialog a phantom table shows up in the list named "__pgsql2shp_tmp_table". Whenever I try to load a shape from this database it fails, and the postgres error console shows it asking for one of the columns in this phantom table, regardless of the table I am actually asking for.  This even happens when using p2sql2shp from the command line regardless of the query I put in.  It shows up in multiple clients (2 different workstations) and seems to affect only this database. I can load things fine from other databases.  I have restarted my postmaster process to no avail, and am currently performing a "vacuum full" in hopes that this will solve it.
> I will report back if this solves the problem, but I am thinking this may be an obscure bug in the shp2pgsql routine. Any clues?
> thanks
> Robert W. Burgholzer
> Nonpoint Source Data Analyst
> University of Maryland, College Park
> Chesapeake Bay Program Office
> 410 Severn Avenue, Suite 305B
> Annapolis, MD, 21403
> Phone: (410) 267-5779
> rburghol at chesapeakebay.net
> http://www.chesapeakebay.net/
> postgis-users mailing list
 /"\    ASCII Ribbon Campaign
 \ /    Respect for low technology.
  X     Keep e-mail messages readable by any computer system.
 / \    Keep it ASCII.
